The Transform tool correlates the same road (routes) from two differing systems by location and tolerance. In my case I am in a urban environment and this technique has very poor results. I had to resort to a differing technique....
In my case I normally work with our LRS system and receive data from a State LRS which is very different in structure and rules from our own:
My process is simply event map my data on our system to get the points of interest along with the route and milepost. With that data set, I add a field to place the other route systems designation eg RouteNameOther. I populate this field from a dataset I maintain that looks up the corresponding routes (how I initially created this lookup see below). With the other routes populated I then re-event map this to the other system the result is a data set with both References (Mileposts) from both systems. Of course I have automated this by creating my own add-in using VB.Net I could never get a "Model" to do this cleanly and handle the differences between two differing structures and rule sets cleanly.
Route lookup table initial creation
I initially populated this lookup table by placing points at the midpoints of our "centerline: segments (from which our LRS was developed from) and intersecting that with the other systems centerline segments to pickup the other route name for the other system for the corresponding routes. That takes care of the minimum requirements to event map (Route and a Point). Over the years, I have maintained this lookup table till it is very clean and is corrected for the different geometric structure and naming convention rules between the two systems. On my first pass for cleaning the lookup table I used the offset distance to help Identify discrepancies. I then looked at over and under routes and overpasses to make sure that these routes were Identified correctly. Be advise you will have to handle 1 to many relationships in translating routes systems in this manner for example we may have route 112 from MP 0 to 15 Miles and the other system this is divided up into route 1A and parts of route 2B and visa versa from the other system to ours.... these types of scenarios I use a segment Id that I place on our system in terms of our centerline break point rules. On the other system I also create a field if it is not there for a segment id and auto uniquely populate it... I then use the segment Id to resolve any Many to Many relationships. Note I have to do this because our rules and structure are vastly different.
I hope this triggers some other Ideas for you!
