Jeff,
First off, I want to say THANK YOU THANK YOU VERY MUCH. I have already used the sample you gave me and added a dialog that I will need and it worked flawless. I was briefly looking through the code, and didn't see anywhere that you specified the orders inbox. I am assuming that if a routing folder is not specified, then the order is added just to the inbox itself? We are constantly moving orders in and out between folders, so I think the way it is setup right now will work perfect for our workflow, but I may need to do the routing folder direct insert in the future. I also have another question in regards to the amount of adds/edits/deletes that we do on a daily basis. This is in regards to the gdb size itself. Can I ask you that question in this thread, or should I create a new thread for that.
Thank you again for all your help,
Josh
