Line Offset
2056
05-07-2012 12:05 PM
EmraSERT
Dear All, I have a feature class and my feature has 88 line records, this records has line number field (1-88), I want to create a offset according to line number, I will want to go 10 meters offset inter lines according to line number, according to this situation first line number is offset position is 0 then second line offset amount 10 m, third line offset amount 20 m .... and last line offset amount 880 m. How to I doing for this situation. (Note: I was trying Geotools, Schema, Buffer, Editing-Offset)? Please help for this situation.
JoshuaDamron
Greetings,
  It sounds like your intent is to offset the lines to create new line features to each side to your current line feature.  It sounds like you want a method to perform this task en masse, not offsetting each feature individually with the offset tool.  If this is the case then I do not know the magical answer to your question.  I would suggest reposting your question in the Editing Forum as your question is not so much related to transportation as it is related to line editing functions.  Also the Editing forum tends to get a lot more traffic.
However, if your goal is to offset your lines for map symbology purposes, then your problem is symbology/cartography related and I would suggest learning about Symbolization: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00s60000000p000000.htm  or (if you have an Editor/Info license) Representation: http://webhelp.esri.com/arcgisdesktop/9.3/tutorials/reps/Reps_8.htm
Hope this helps!
