No, ArcLogistics VRP solver will give the best answer based on the constraints you set. If you're not happy with route results, you should explore altering these constraints.
Also, I don't think ArcLogistics can import an OD matrix to use. Maybe if you wrote a plugin it would be possible but this is a task better suited for Network Analyst extension.
