Hi Christian,
Thanks for your answer! It works for finding 10 worst intersections. However, I still have the problem with Hot Spot Analysis. Since I only want to obtain a Hot Spot Map for intersection buffers (all pink ring buffers), which means my polygon are not contiguous, and I tried to use the tool that you recommended, but it failed to output. May I have any suggestion for that? Thank you very much!
Lanxi
