I'm currently busy re-writing the following Python Module:
I have just realised that ArcHydro doesn't recognize the arcpy.env.workspace or the ArcHydroTools.SetTargetLocations("HydroConfig", "Layers", "RasterWorkspace", "VectorWorkspace")
Created on March 13, 2017
ArcHydro Main Model
@author: PeterW
from pathlib import Path
import arcpy
import ArcHydroTools
rasters_workspace = r"E:\Projects\2016\G113386\ArcHydro\Model01\Layers01"
dem = r"E:\Projects\2016\G113386\DEM\raw"
fgdb_workspace = r"E:\Projects\2016\G113386\ArcHydro\Model01\Model01.gdb"
arcpy.CheckOutExtension("Spatial")
arcpy.env.overwriteOutput = True
def rasters_main(rasters_workspace, dem):
""" Create Rasters as part of ArcHydro Pre-processing"""
arcpy.env.workspace = rasters_workspace
ArcHydroTools.SetTargetLocations("HydroConfig", "Layers", rasters_workspace, fgdb_workspace)
arcpy.AddMessage("Processing Fill Sinks")
ArcHydroTools.FillSinks(dem, "fil")
Python Module: arcpy.env.workspace and ArcHydroTools.SetTargetLocations ignored by ArcHydro
File "E:\Python\Eclipse\2015\arcpy64bit\src\archydro\archydro_main_test.py", line 34, in <module>
File "E:\Python\Eclipse\2015\arcpy64bit\src\archydro\archydro_main_test.py", line 31, in rasters_main
File "C:\Program Files\ESRI\WaterUtils\ArcHydro\bin\ArcHydroTools.py", line 6805, in FillSinks
raise e
arcgisscripting.ExecuteError: You need to set either the geoprocessing Workspace or the Arc Hydro Raster Location before running the tool.
Failed to execute (FillSinks).
Error Message:
I'm currently using ArcGIS 10.3.1 and ArcHydroTools 10.3.0.78
