I am mapping out a delta area with hundreds of polygon rivers. The rivers all need to monotonic, and I am using LiDAR data. After draping the vector lines to the .las file and then flattening the rivers, the intersection between secondary rivers and the primary rivers have a small elevation difference. Is there a solution to this problem, without having to go to each intersection and changing the Z elevations by hand to make sure that rivers stay monotonic?
