I have installed the HecGeoHMS 10.1 on a laptop running ArcGIS 10.1. I try to use the "Preprocessing tools" and the demo-dataset from "American River". All the points on the "Preprocessing tools"-menu run nicely without problems until i come to the last thing on the list: The Adjoint Catchment Processing. When using this tool i get a lot of errors, the first of them is: System.Runtime.InteropServices.COMException(0x80004005)
As far as i know i do need this file of Adjointment of Catchments to proceed to the next task in the HecGeoHMS - but i really have no ideas about what is wrong or what i should do to fix the problem. Therefor i REALLY HOPE that somebody could help me a bit further - what am i doing wrong and what do i need to do to make this file with the aggregated catchments? Or - maybe it is possible to go to the next task without having this file?
The first things I'd try are clearing out the temp files and turning off the background processing. Also, I assume you are working with data on you laptop and not on a network. Working locally eliminate errors for some reason. Lastly, I'm not working with 10.1 and so there could be something else going on related to the operating system.
So - i read through all the posts that MBoucher21 has written and linked to - and something of all those tips did the trick!! So - now is everything running smoothly and fine - thanks again for the excellent help!! 🙂
