I am running Depression Evaluation in ArchHydro (AchGIS 10.4) and keep getting the following error:
System.Runtime.InteropServices.COMException (0x80041098):
ERROR 010316: Unable to open the input raster: C:\USERS\PMH\APPDATA\LOCAL\TEMP\ARCF98B\AH2016~4\G_G2432
ERROR 010067: Error in executing grid expression.
ERROR 010218: Could not reference the raster dataset.
at ESRI.ArcGIS.SpatialAnalyst.RasterConditionalOpClass.Con(IGeoDataset ConditionalRaster, IGeoDataset TrueRaster, Object& FalseRaster)
at ESRI.APWR.ApHydro.ArcHydroOp.DepressionEvaluation(ApProgworkMgr& apProgMgr, String configNodeName, ApLayers apLayers, Double zUnitFactor, Int32 debug, ITrackCancel& trackcancel, IGPMessages& messages, String& exMessage) in C:\Builds\HydroSolutions\10.4_ArcHydro\Sources\ArcHydroTools\src\ApHydro\ArcHydroOp.vb:line 58174
Failed to execute (DepressionEvaluation).
I have cleared out the TEMP folders, make the directory "AH2016~4" and none of that works.
