Re: Arc Hydro -- disable XML creation
1482
10-01-2013 03:26 AM
AndrewZimba
Does anyone know how to turn off the setting that makes ArcHydro save an xml file for each mxd that is saved (with the same name and in the same folder as the mxd).
I know Archydro is the culprit.  When I remove it, the behavior stops, and when I re-install, it starts again.
Thank you in advance!
ChristineDartiguenave
Arc Hydro edits the ArcGIS configuration file ArcMap.exe.Config (located in the ArcGIS installation directory, e.g. "C:\Program Files\ArcGIS\Desktop10.1\bin\ArcMap.exe.Config") during its installation.
It appends an  <appSettings> section with all the entries listed below and in particular.
  <add key="ESRI.APWR.SaveXMLInMap" value="true" />
If this key is not found then the xml will be saved to the disk when the mxd is saved.
Reinstalling Arc Hydro should fix the issue or you can append the section below in your config file.
We will look into modifying this behavior so that the xml does not get created if the node is not found.
Christine Dartiguenave
Esri Water Resources Team
ArcMap.exe.Config File
<?xml version="1.0" encoding="utf-8"?>
<configuration>
  <appSettings>
    <add key="ESRI.APWR.DebugLevel" value="0" />
    <add key="ESRI.APWR.LogFilePath" value="C:\TEMP" />
    <add key="ESRI.APWR.LogFileName" value="AP" />
    <add key="ESRI.APWR.UNIQUEIDTABLE" value="APUNIQUEID" />
    <add key="ESRI.APWR.LAYERKEYTABLE" value="LAYERKEYTABLE" />
    <add key="ESRI.APWR.UNIQUEIDFIELD" value="LASTID" />
    <add key="ESRI.APWR.LAYERNAMEFIELD" value="LAYERNAME" />
    <add key="ESRI.APWR.LAYERKEYFIELD" value="LAYERKEY" />
    <add key="ESRI.APWR.IDNAMEFIELD" value="IDNAME" />
    <add key="ESRI.APWR.IDFLDNAME" value="IDFLDNAME" />
    <add key="ESRI.APWR.UIDS" value="HYDROID,HYDROID|MID,MARINEID" />
  </appSettings>
</configuration>
