River Slope Errors
2345
07-14-2021 04:56 PM
Labels (2)
Eng_A_SH
New Contributor III
Greetings.
I'm using a Geographic Coordinate System ( WGS84 ). And i've used an SRTM DEM while using the hecgeo HMS extension on ArcMap. I've got all the way to [ Characteristics ] > [ River Slope ] and it showed me this error.
I tried fixing it by adding a Z factor of 1 - Which is the default - by using [ 3D analyst ] > [ Slope ].
I named the result WatershedFactor1
This error showed up :
Would appreciate the help.
Thank you.
by Anonymous User
Not applicable
Hi @Eng_A_SH ,
you can disable the back-end process and run the processes in the foreground of ArcGIS Map,
Here is a link that can help you with the disabling process.
 ArcGIS Help 10.1 - Foreground and background processing
Eng_A_SH
New Contributor III
Hi @Anonymous User .
Thanks for the response. Unfortunately this did not work out.
The following error screen appears :
by Anonymous User
Not applicable
Hi @Eng_A_SH ,
Can you have a look at what the DEM Georefence is, is it referenced?
Eng_A_SH
New Contributor III
These are the properties of the RawDEM layer
DeanDjokic
Unfortunately, GeoHMS tools do not manage data in GCS.  While most tools will work with it (e.g. terrain preprocessing and subbasin delineation), once you get into calculation of stream and watershed characteristics, GCS is not supported.  There are workarounds, but you are better off projecting the DEM and starting from scratch (you cannot just project all raster derivatives).
