Hi Christine,
I think I am using the 64 bit version from the 10.5.0.90 folder. The input data is a stand-alone GRID. The operation works fine from the Terrain Preprocessing Menu.
Now, when I run it from , I am getting the following error messages:
Messages
Executing: DepressionEvaluation DEMs\df_ldem_15 C:\GIS\Working_Folder\kunz_farm_archydro.gdb\Layers\Depression_15mG3 C:\GIS\Working_Folder\kunz_farm_archydro.gdb\Layers\DepressionDA_15mG3
Start Time: Thu Jan 10 08:05:08 2019
System.NullReferenceException: Object reference not set to an instance of an object.
at ESRI.APWR.ApHydro.ArcHydroOp.DepressionEvaluation(ApProgworkMgr& apProgMgr, String configNodeName, ApLayers apLayers, Double zUnitFactor, Int32 debug, ITrackCancel& trackcancel, IGPMessages& messages, String& exMessage) in C:\Builds\HydroSolutions\10.5_ArcHydro\Sources\ArcHydroTools\src\ApHydro\ArcHydroOp.vb:line 58020
Failed to execute (DepressionEvaluation).
Failed at Thu Jan 10 08:05:11 2019 (Elapsed Time: 3.44 seconds)
Messages
Executing: DepressionEvaluation DEMs\df_ldem_15 C:\GIS\Working_Folder\kunz_farm_archydro.gdb\Layers\Depression_15mG4 C:\GIS\Working_Folder\kunz_farm_archydro.gdb\Layers\DepressionDA_15mG4
Start Time: Thu Jan 10 08:15:21 2019
System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
at ESRI.ArcGIS.Geoprocessing.GPUtilitiesClass.IGPUtilities2_DecodeRasterLayer(IGPValue pValue, IRasterDataset& ppRD)
at ESRI.APWR.ArcHydroGPTools.ApConfigGP.UpdateInputApLayerWithData(ApProgworkMgr& apProgMgr, String configNodeName, String mapElementName, IGPValue gpValue, ApLayer& aplayer, String& exMessage, String& exWarning) in C:\Builds\HydroSolutions\10.5_ArcHydro\Sources\ArcHydroTools\src\ArcHydroGPTools\ApConfigGP.vb:line 2475
Failed at Thu Jan 10 08:15:25 2019 (Elapsed Time: 3.66 seconds)
Garret
