Create Linked Record
613
02-07-2020 07:13 AM
MikeOnzay
Occasional Contributor III
Is it possible to use this method to create a new record in a related table when a feature is created in a layer? If not, are there any method or series of methods that can be used to achieve this result?
MikeMillerGIS
Esri Frequent Contributor
I would have to verify, but I recall issues with the eventing, that the id to link to the related record is not available to the AA in the on create event.
Jared_Motuz
Mike Onzay‌,
The following GeoNet post looks to provide a good example of using the Create Linked Record method to generate a new record in the related table on creation of a new feature.
Attribute Assistant Create Linked Record
https://community.esri.com/thread/184150-attribute-assistant-create-linked-record
Hope this helps!
-Jared
