Any ideas as to where to get help when something fails?
I configured the dynamic table to get some values from a master street table into the SiteAddressPoint table using the Validate attribute lookup method. It did not work.
I set the AA to debug and found that a couple of fields were not found. I have no idea where these fields are searched because both, the SiteAddressPoint and Master tables have the fields.
This is the configuration on the dynamic table:
TABLENAME: SiteAddressPoint
FIELDNAME: FULLNAME,PREDIR,STNAME,STTYPE,STTYPE1, STTYPE2, ALTUNITTYPE
VALUEMETHOD: VALIDATE_ATTRIBUTE_LOOKUP
VALUEINFO: MasterStreetName|FULLNAME, ROADPREDIR, ROADNAME, ROADTYPE, ROADTYPE1, ROADTYPE2, RAMP
Both sets of fields exist, FIELDNAME fields are from siteAddressPoint, and Fields from VALUEINFO exist in Master Street name.
The logfile states the rule was not processed:
Row Info
Row Number 8
TableName: SiteAddressPoint
FieldName: FULLNAME,PREDIR,STNAME,STTYPE,STTYPE1, STTYPE2, ALTUNITTYPE
ValueInfo: MasterStreetName|FULLNAME, ROADPREDIR, ROADNAME, ROADTYPE, ROADTYPE1, ROADTYPE2, RAMP
ValueMethod: VALIDATE_ATTRIBUTE_LOOKUP
On Create: 1
On Change: 1
Checking for Subtype Restriction <------ I do not know where this is
Field Name: Street Name was found at index: 12 <---- I am not sure where "Street Name is"
Field Name: QUADRANT was found at index: 43 <---- or quadrant
Field Name: STNAME was found at index: 44
Field Name: STTYPE was found at index: 45
Field Name: STTYPE1 was found at index: 54
STTYPE2 Field not found <------ These two fields exist in SiteAddressPoint
ALTUNITTYPE Field not found
Rule not processed
Any help would be appreciated.
It searches the TOC, not by layer name, but feature class name. Could there be a table with the same gdb name?
Unfortunately, that is not the case. the TOC has spaces in it, the actual FC do not. They are MasterStreetName and SiteAddressPoint.
Thank you
It does not use the TOC name, just the Feature Class Name. Some pictures of the map and your dynamic value table would be helpful
