Trouble with Water Distribution Data Management Solution and Field Maps
1104
12-08-2022 02:09 PM
DanAllen
Occasional Contributor III
HELP!
I posted this same question in the Field maps community section, but I think it might be more related to the water distribution data management solution.
I setup the ESRI water distribution solution, hosted on ArcGIS Online.  I then used the asset collector map it gives you with the Field Maps app to collect some GPS data for fire hydrants and valves.  When I submit the features, it looks like they save with no error codes.  The points show up on the map in your current session, but they do not show up in the hosted feature service in ArcGIS Online.  Once I close the Field Maps App (ios and android versions), the points I just collected have vanished.  One other odd thing, after I "submit" a new feature in the Field maps app, is shows that it gave it a "negative" object id number.  It starts at OID -10, then -11, -12 and so on.
Any ideas what is going on here?  I have been using Collector and Field maps for several years, and never experienced anything like this behavior.
I am using the latest  version 2.0 of the water distribution solution.
thanks
Dan
JoelSmith3
Hi Dan, I'm seeing the same thing in my org. Could you log a technical support request? I'll keep looking into it on my side and will post back here as soon as I know more.
Joel
DanAllen
One thing i noticed, is that when you publish a new install of the water solution to arcgis online, the master water distribution feature layer has editing turned off by default, yet the hosted feature layers have editing turned on.  I thought this was the source of the problem, but it still persists.  I may have time to contact support today.
JoelSmith3
I tried to replicate the issue on my iPad (with an older version of Field Maps) and I was able to submit edits with correct OIDs. But when I updated to the latest version of Field Maps the issue returned. The Field Maps team is aware and working on the issue.
DanAllen
Well that is good to know.  If it is a bug with field maps, i sure hope they push out an update quickly.
