I am working with a water database, which has WTP, pipe, valves and meters feature classes. I've created a geometric network on the feature dataset, making meters as sinks and WTP as sources. However, my pipeline structure has many loops in their geometry and when I used the Set Flow Direction tool (based on their role - sink and source) it has created many indetermined flow edges. I've checked some workarounds (as stableshing only sinks or only sources in my geometric network) but it doesn't work also. Is there any way to fix that? Or the tool will always point as indetermined flow when it's possible to run in both direction (loop)? Is there any way I can indicate some direction with this tool, for example, select a pipe and chose if it goes upstream or downstream for the pipeline wihtout using the digitized direction?
I'm using ArcGIS Desktop 10.5.
Thank you very much!
Diogo Reis
