I have a custom panel widget in WAB Developer edition. On the panel is a dijit/form/Button. It has a css class that gives it a color. It also has a label "Start Tool." There is a data-dojo-attach-event = "onClick:mytogglefunction."
In my widget code I have mytogglefunction, which uses an if/else pattern to look for the label state and change it to a different label "Stop Tool" and also change the css class (so button gets a different color when clicked and activated.)
Problem: user clicks once on button. Label changes immediately onclick, but css color doesn't change until the mouse pointer rolls off the button. So there are essentially 2 events happening -- the click, then the onmouseout.
As I understand it, this is not a css :hover problem. I want the css to update on one onclick.
I created a similar button in a CMV application that worked fine -- but I don't know what is controlling this behavior in WAB.
Help! Thank you!
I am not sure what difference setting the baseclass and the dom nodes class make but I am glad you got it working.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Thank you for helping me once again!
Sure thing. Just some forum etiquette though when someone provides a reply that is helpful you should mark it as such. Since my replies did not produce the correct answer for you, marking your own is ok.
Of course! I couldn't have solved this without your answer. Since I can't mark 2 answers, I have changed the mark.
