Jessie,
From looking at the documentation:
Screening widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
It says this:
Click the Download tab, and under Download Settings, choose one of the following options:
- Feature Layers—Choose the layers you want downloaded. This option supports CSV file and, when the layer is a feature service with sync enabled, file geodatabase and shapefile downloads.
- Extract Data Task—All layers are enabled for CSV file download, and feature data can be downloaded as file geodatabases or shapefiles with the Extract Data Task geoprocessing service.
- Disable download—No data download is enabled with this option.
You have to have the Extract Data Task geoprocessing service in order to extract or download geospatial data like shapefiles. Without this service, you can only download CSVs, like you currently see.
For help on sharing a geoprocessing service, like Extract Data Task, please see the example here:
Geoprocessing service example: Clip And Ship—ArcMap | ArcGIS Desktop
