eDraw widget
73577
250
02-24-2015 01:17 AM
JeremieCornet1
Occasional Contributor II
Ehanced draw widget for WebApp Builder for Arcgis
UPDATE 2018/05/09 (new Release v2.8.1) :
  • refactoring
  • use esri/geometry/projection (available since esri js api 3.24) instead of proj4js (external libs)
  • systematic use of geometry engine (no more mercator utils, geometry server...)
  • for polyline, the user can now add an arrow (available since esri js api 3.23)
  • live measure while drawing
  • WARNING : this release needs Esri API >= 3.24
Release 2.8.1 on Github
(Direct zip link : https://github.com/magis-nc/esri-webappbuilder-widget-eDraw/releases/download/v2.8.1/eDraw.zip )
Demo : https://apps.magis.nc/demo/eDraw/
Github  :
Wigdet's Features (improvments of standard Draw widget) :
  • add name and description fields on drawings
  • enable infowindow on drawings (selection)
  • on text drawing, no insert if no name.
  • on modification : enable geometry update (with snapping if wanted : CTRL) and preview symbology changes on the fly
  • list
    • add list of all drawings
    • actions on each drawing : modify / delete / [up / down] / zoom
    • all drawings : zoom, copy, delete, export
    • on drawing infowindow -> select drawing in list
    • on zoom on a drawing -> select drawing on map (and show infoWindow)
    • re-order graphics with drag&drop
  • import/export : allow users to export or import drawings (json format)
    • import can be done with file drag&drop in import popup
  • localStorage
    • dynamic saving on each drawing add/delete/update
    • on widget load : load drawings saved in local Storage
  • draws plus (initially from Larry Stout https://geonet.esri.com/people/Larry_Stout)
    • preview under mouse when adding text or point
    • for text, add font choice, font angle, bold, italic, placement and underline options.
    • add arrow menu for polyline
  • checkbox to hide drawing's layer (and therefore widget UI)
  • add of Nautical unit
  • measure's for points/polylines/polygons with automatic update on element's update (or delete). Measure's can be indidualy disabled/enabled on any graphic.
  • "On the fly" measure when drawing
  • defaults symbols can be specified in config's file
  • use of builtin projection engine (available since esri js api 3.24) instead of proj4js library
This message was updated by Jeremie Cornet (New Release)
ZachSchmitt
New Contributor III
Thanks Jeremie. This may not be exactly the goal of the widget as well, but when a user has several drawings in the drawings list, it would be nice for the user to export an individual drawing within the drawing list, not the entire list.
JeremieCornet1
Zachary Schmitt​ Good idea. I will add it in a future release.
HumzaAkhtar
Hi,  Thanks for this widget. I wanted to ask if it is possible to publish the json file to ArcGIS online account as a GeoJSON?
MonikaHonkova1
Hello,
great widget! Works fine in WAB Dev Edition 1.1. I upgraded to WAB DEV Edition 1.2 but it seems that it will need a few tweaks to make it work in the latest edition?
"create widget error:
widgets/eDraw/Widget"
Have you experienced any issues with the latest edition yourself?
Thanks, Monika
JeremieCornet1
Hello Monika,
Could you describe your context (browser(s), wab theme...) and, if possible, paste the whole error ?
I have some style's issues with new themes but the widget works for me.
MonikaHonkova1
Hi Jeremie,
I'm using Firefox 38.0.5. I have tried IE10 as well (10.0.9200.17413).  I tried every single theme which is available in WAB 1.2 - error message below:
Thanks, Monika
JeremieCornet1
I havn't understood it was in the builder and in the widget configuration.
In deployed apps, the widget still works well with wab dev 1.2.
I can reproduce the error so i will dig it.
JeremieCornet1
New release for WAB 1.2
Monika Honkova​ Issue corrected
AdamGebhart
Occasional Contributor III
@Jeremie Cornet - is it possible to have the measurements update as the shapes are modified?  Or is there a way to create a new measurement based on shape modifications?
JeremieCornet1
Adam Gebhart​ It's not possible now.
You're not the only one who wants that functionnality
I will add it in a future release but it's a big change in widget's architecture.
