Enhanced search limiting features
2890
09-09-2015 06:34 AM
LeoLadefian4
using the enhanced search is limiting my results to 2000 features.  I am using a hosted feature service.  I assume I need to change the server return records?
RobertScheitlin__GISP
Leo,
   Correct the eSearch does not bypass the max returned features that the server has set like the Query widget does.
Leo,
LeoLadefian4
Gotcha, is it scale dependent as well? I seem to be getting some strange search results.  Also, do the services need any specific settings when they are created? update, query, etc?
Leo,
   just query. You need to ensure that the ObjectId field and the Shape fields are not hidden in the mxd when you publish the map service as well. Scale dependency is removed from the layer when using eSearch.
