Hi Robert,
As you suggested, here is the new thread on this problem. to recap, the search functionality works fine and I currently have it set to "Add Result as Operational Layer." I am searching against a point layer. Everything looks great until I use the out of the box print tool. When I do a print, the point symbols come out huge. Changing the symbol or its size has no effect. I have also tried changing all of the Advanced settings, map scale, extent, etc. with no luck.
I am using Widget Version 1.1.8 and Web AppBuilder 1.1. Aside from the two images, I've attached a zip file containing the entire Web App.
The first image is how it looks on the screen.
Printed pdf.
