Hello Robert Scheitlin, GISP, we are using the esearch widget and noticed the export to csv produces an empty table when add results as operational layer is not checked. Is this expected behavior?
Jonathan,
That issue was fixed a while back so you must be using an older version of WAB and the eSearch. If you update to 2.4 you will not experience that issue.
Jonathan,
Ok, thanks!
