Failure to clear map graphics in Javascript
4163
08-10-2015 01:33 PM
TylerJones3
New Contributor III
I have two graphics layers I am using to track a user's searches in a custom widget. Users are allowed to search using partial query strings; their results are written out to a datagrid and the matching features are shown on the map using blue circles in a graphicslayer I named GLayerResults.
There is a second graphics layer for when a user clicks on an item in the datagrid. The selected feature will then highlight on the map using a red square. This graphics layer is named GLayerDGSel.
The first iteration works correctly; a partial search will return multiple features which highlight on the map and then clicking on one of the features in the datagrid highlights that feature with a red square.
Two problems occur after this: 1)Clicking on a different feature will clear the original red square but the blue circle disappears too which should not happen and 2)Panning or zooming the map after results in all prior red squares reappearing on the map at once even though they were cleared. How do I keep these features permanently cleared?
Code below (the graphics layer clear happens on line 148).
define([
      'dojo/_base/declare',
      'dijit/_WidgetsInTemplateMixin',
      'jimu/BaseWidget',
      'dojo/parser',
      'dojo/_base/lang',
      'dojo/_base/query',
      'dojo/_base/html',
      'dojo/_base/array',
      'dojo/_base/fx',
      'dojo/promise/all',
      'dojo/Deferred',
      'esri/map',
      'esri/layers/GraphicsLayer',
      'esri/graphic',
      'esri/graphicsUtils',
      'dojo/on',
      'dojo/dom',
      'dijit/registry',
      'dojo/_base/connect',
      'dojo/_base/array',
      'dojo/data/ItemFileReadStore',
      'esri/tasks/query',
      'esri/tasks/QueryTask',
      'esri/layers/FeatureLayer',
      'jimu/MapManager',
      'esri/geometry/Extent',
      'esri/Color',
      'esri/symbols/SimpleMarkerSymbol',
      'esri/symbols/SimpleLineSymbol',
      'esri/InfoTemplate',
      'dojox/grid/DataGrid',
      'dijit/layout/BorderContainer',
      'dijit/layout/ContentPane'
function(declare, _WidgetsInTemplateMixin, BaseWidget, parser, lang, query, html, array, fx, all, Deferred, Map, GraphicsLayer, Graphic, graphicsUtils, on, dom, registry, connect, arrayUtils, ItemFileReadStore, Query, QueryTask, FeatureLayer, MapManager, Extent, Color, SimpleMarkerSymbol, SimpleLineSymbol, InfoTemplate){ //a
  parser.parse();
  //To create a widget, you need to derive from BaseWidget.
  return declare([BaseWidget, _WidgetsInTemplateMixin], { //b
    // Custom widget code goes here
    baseClass: 'jimu-widget-nessearch',
    GLayerResults: null,
    GLayerDGSel: null,
    testLayer: null,
    selGraphic: null,
    //methods to communication with app container:
    postMixInProperties: function(){//1
      this.inherited(arguments);
    },//1
    startup: function(){ //c
      console.log('startup');
      testLayer = new GraphicsLayer({id:'test'});
      testLayer.url = "test_sel";
      GLayerDGSel = new GraphicsLayer({id:'dg_sel'});
      GLayerDGSel.url = "dg_sel_url";
      this.map.addLayer(GLayerDGSel);
      GLayerResults = new GraphicsLayer({id:'dg_res'});
      GLayerResults.url = "dg_res_url";
      this.map.addLayer(GLayerResults);
    }, //c
    _onPointBtnClicked: function(){ //d
      var query = new Query();
      query.outSpatialReference = this.map.spatialReference; //The basemap's spatial reference does not match the other layers. Set the query to match.
      query.returnGeometry = true;
      this.map.graphics.clear();
      GLayerResults.clear();
      var queryTask, infoTemplate, store;
      switch (dom.byId("SelectType").selectedIndex) { //e
        case 0: //Pole
          queryTask = new esri.tasks.QueryTask("http://utility.arcgis.com/usrsvcs/servers/3de80160798b44879737f6d2b050994d/rest/services/NES/Electri...");
          query.outFields = ["POLE_NO", "PNO", "NODE_ID"];
          query.where = "UPPER(POLE_NO) LIKE UPPER('%" + dom.byId("SearchValue").value + "%')";
          infoTemplate = new esri.InfoTemplate("${POLE_NO}", "Pole Number : ${POLE_NO}<br/> PNO : ${PNO}<br/> NODE_ID : ${NODE_ID}");
          break;
        case 1: //XFMR
          query.outFields = ["XFMR_NO"];
          query.where = "UPPER(XFMR_NO) LIKE UPPER('%" + dom.byId("SearchValue").value + "%')";
          break;
        case 2: //SWNO
          query.outFields = ["SWNO", "POLE_NO"];
          query.where = "UPPER(SWNO) LIKE UPPER('%" + dom.byId("SearchValue").value + "%')";
          queryTask2 = new esri.tasks.QueryTask("http://utility.arcgis.com/usrsvcs/servers/3de80160798b44879737f6d2b050994d/rest/services/NES/Electri...");
          query2.outFields = ["SWNO", "POLE_NO", "NODE_ID"];
          query2.where = "UPPER(SWNO) LIKE UPPER('%" + dom.byId("SearchValue").value + "%')";
          infoTemplate = new esri.InfoTemplate("${POLE_NO}", "Pole Number : ${POLE_NO}<br/> SWNO : ${SWNO}<br/> NODE_ID : ${NODE_ID}");
          break;
      } //e
      var markerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 15, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 204]), 1.5), new Color([0, 0, 255, 0.5]));
      queryTask.execute(query, lang.hitch(this, showResults)) //Use lang.hitch, otherwise the wrong "this" will be obtained.
      //queryTask2.execute(query2, lang.hitch(this, showResults))
      function showResults(featureSet){//3
        //QueryTask returns a featureSet.  Loop through features in the featureSet and add them to the map.
        //Performance enhancer - assign featureSet array to a single variable.
        //New Datagrid code***********************************************
        //create array of attributes
        var items = arrayUtils.map(featureSet.features, function(feature){//4
          return feature.attributes;
        });//4
        //Create data object to be used in store
        var data = {//5
          identifier: "POLE_NO", //This field needs to have unique values
          label: "PoleNumber", //Name field for display. Not pertinent to a grid but may be used elsewhere.
          items: items
        };//5
        //Create data store and bind to grid.
        store = new ItemFileReadStore({//6
          data: data
        });//6
        function onRowClickHandler(evt){//9
          var clickedFeature = evt.grid.getItem(evt.rowIndex).POLE_NO;
          var selectedFeature = arrayUtils.filter(GLayerResults.graphics, function(graphic){
            return ((graphic.attributes) && graphic.attributes.POLE_NO === clickedFeature);
          if (selectedFeature.length) {
            var spGraphic = selectedFeature[0];
            var resmarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 20, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SQUARE, new Color([255, 0, 0]), 1.5), new Color([255, 0, 0, 0.5]));
            GLayerDGSel.clear(); //does not work; item draws back in when panning.
            if (spGraphic.geometry.type === 'point') {
              spGraphic.setSymbol(resmarkerSymbol);
              GLayerDGSel.add(spGraphic);
        };//9
        this.ResultsGrid.setStore(store);
        this.ResultsGrid.on("rowclick", lang.hitch(this, onRowClickHandler));
        var resultFeatures = featureSet.features;
        if (resultFeatures.length > 0) {//7
          for (var i = 0, il = resultFeatures.length; i < il; i++) {//8
            //Get the current feature from the featureSet.
            //Feature is a graphic
            var graphic = resultFeatures;
            graphic.setSymbol(markerSymbol);
            //Set the infoTemplate.
            graphic.setInfoTemplate(infoTemplate);
            //Add graphic to the map graphics layer.
            //this.map.graphics.add(graphic);
            GLayerResults.add(graphic);
            var myFeatureExtent = esri.graphicsExtent(resultFeatures);
            this.map.setExtent(myFeatureExtent.expand(2.5));
          }//8
        else {
          //alert("No features were found using the provided search string.");
        }//7
      }//3
      return;
    } //d
  }); //b
}); //a
TylerJones3
New Contributor III
I got it working. Those lines were not part of the problem, instead it was line 143. Ultimately I was working with the original graphics and not the new selected graphics layer like I thought I was. The correct version of this should be, starting at line 143:
           var spGraphic = new Graphic;
           spGraphic.setGeometry(selectedFeature[0].geometry);
RobertScheitlin__GISP
Tyler,
    You have to use this dot for global vars in your widget code. I have made other comments in your code as well.
TylerJones3
New Contributor III
Thanks; I did not know "this." was necessary for globals. Unfortunately, the problem where the selection graphics layer replaces the search graphics layer persists and the selection graphicslayer graphics continue to re-appear when the map is zoomed or panned even though they were supposedly cleared.
TylerJones3
New Contributor III
I should add that I strongly suspect that lines 139 to 141 of the code above are the problem area. It appears to be setting the red square selection graphic onto the wrong graphicslayer. I am unclear how that is occurring though.
TylerJones3
New Contributor III
Tyler,
   Glad you figured this out. Don't forget to mark this question as answered.
