GeoRSS Widget - Web AppBuilder for ArcGIS
2676
01-10-2017 06:11 AM
BenGrod
Occasional Contributor III
Is there a GeoRSS Widget for Web AppBuilder for Developers (Portal or ArcGIS Online) similar to this Flex Viewer GeoRSS Widget.I am currently at version 10.3.1 on Portal for ArcGIS.
RobertScheitlin__GISP
Ben,
   There is not one I am aware of.
BenGrod
Thanks Robert, checking that out now. Not sure it will deliver exactly what I want but you are correct in that it does support GeoRSS feeds.
BenGrod
The Add Data Widget definitely supports GeoRSS feeds but it puts the responsibility on the end user to have the URL and add it to their map individually. Thank you so much for the directing me towards the Add Data Widget but I was hoping to find a widget that could be preconfigured for one or more GeoRSS feeds.
Ben,
BenGrod
Thanks Robert, I think you are correct and will check the box shortly, just want to search around a little longer!
