how to change the width and height of the custom widget pragmatically in launchpad theme?
3203
6
02-04-2016 06:51 AM
MS2
how to change the width and height of the custom  widget pragmatically in launchpad theme?. Setting in config file using position key and using the below code is not working for me. Is it a bug or am i missing something?
var pos = {
          width: '600px',
          height: '500px'
html.setStyle(this.domNode, pos);
RobertScheitlin__GISP
Mouli,
   These two threads will help explain why you can not do this in the config.json like other themes:
Launchpad theme and panelmanager problem
Layer List auto start location change
Mouli,
MS2
Thanks for your reply Robert. I want to change the size of the window after some user events( like on a button click), not on start up or from some other widget.  I tried the below line and its not giving me the expected result. Any help will be appreciated. Thanks in advance.
this.setPosition(pos);
PanelManager.getInstance().normalizePanel(this.panel); //PanelManager.getInstance().normalizePanel(this);
Mouli,
   Not knowing what the "pos" var has in it I could not say whats wrong with your code.
MS2
Robert,
"pos" variable is same as the one I mentioned in my question. check below.
var pos = {
     width: '600px',
     height: '500px'
  1. this.setPosition(pos);
  2. PanelManager.getInstance().normalizePanel(this.panel); //PanelManager.getInstance().normalizePanel(this);
Mouli,
   You need to re-look at the first link I provided the "pos" object need more than just width and height.
MS2
Thanks Robert. It helped a lot.
