I have two questions:1. why "Filter" in Attribute Table Widget is greyed out? My data is a shapefile 2. why my layers are not showing up under "Select a layer from current map." in Query Widget in App Builder? Please help. Thank you.
668
02-24-2018 01:25 PM
sarahli
1. why "Filter" in Attribute Table Widget is greyed out? My data is a shapefile.
RobertScheitlin__GISP
Sarah,
  Certain widget do not allow for layers added from the AddData widget. The Attribute Table widget can not use a shapefile for filtering it needs a map service.
sarahli
Robert,
Thank you so much. Does Query widget need a map service as well?
Yes it can not be a shapefile.
