Incorporating graphs into eSearch Widget results
1142
11
08-06-2018 07:14 AM
JustinBridwell2
Occasional Contributor II
I am using Robert's eSearch Widget to bring in some ACS census data in certain areas. Graphically, it displays the results like this:
Lets say I wanted to display the race results as a pie graph. I can easily use `(Math.floor((Total Pop/RacialGroup) * 100).toFixed(1) + "%"); ` or something like that to get the percentage> I have no idea how I could create and insert a small pie graph in the Results under Race to display. Currently, I am using the following to display the results in the widget.js.
thisVar.featLayerTracker +=layerConfig.Label.Population + ": " + sumPOP + "<br>";
 So, I am thinking that I need to perhaps look to layerConfig inthe config_eSearch.json perhaps to set something like this up. Any ideas or suggestions?
RichBell
Thank You, but that is how I set up the info widget.
What I'm needing is some function to "open" the infographic chart from the eSearch.
Something similar to the "Zoom Too", Flash", etc.
by Anonymous User
Not applicable
Rich, I'd also like this.  As well as a direct way to open the Screening widget from eSearch to generate a tabular report.  (the Screening widget creates great reports)
Perhaps for v. 1.1 of my site for the spring or summer.
