I have a number of config.json files under the config folder of the app and I was wondering if I can select the config.json file based on the user's action at runtime. In other words, can I use something like this.config="configA.json"? If yes, what is the proper path syntax to point to the correct json file?
I know another way is to use the custom config as a url parameter but this app is not possible.
Ideas?
Thank you.
