I've been having a blast playing around with the new Web AppBuilder, and have taken a few cracks at putting together some custom Widgets that I'd like to share with the community. I hope these can assist in everyone's future Mappmaking endeavours!
September 28 2017 : LocalLayerWidget v2.5 released: This major release includes the following enhancements for the widget. Thanks to everyone who's donated!:
Release LocalLayerWidget 2.5 · cmndrbensisko/LocalLayer · GitHub
November 14, 2016: LocalLayerWidget v2.2 released: This major release includes the following enhancements for the widget:
Release LocalLayer v2.2 · cmndrbensisko/LocalLayer · GitHub
May 18, 2016: LocalLayerWidget v.2.0 released: This substantial change for Web App Builder v.2.0. removes the need to edit any core files in the Web App Builder, unlike previous versions. A slight change will still be necessary for the AttributeTable widget to work properly with LocalLayerWidget layers.
Mar 29, 2016: LocalLayerWidget v.1.3.1 released; Contains bugfixes to v.1.3. related to custom rendering for Feature Layers and toggling sublayer visibility in the LayerList widget.
Mar 22, 2016: LocalLayerWidget v.1.3 is now available! (Note the version naming change; Version 1.3 refers to its compatibility with v1.3 of the WAB - This is indeed the latest version of the widget as of March 22, 2016). Be sure to read the github page to see what tweaks need to be made to ensure that everything continues running smoothly in version 1.3 of the Web AppBuilder.
Feb 10, 2015: LocalLayerWidget v.1.5 is now available! This release contains full support for adding Tiled layers to your application directly from ArcGIS Server, in addition to the Basemap, Dynamic, and Feature layers available before. Feel free to grab the widget from our Release page located at https://github.com/cmndrbensisko/LocalLayer/releases.
Feb 2, 2015: LocalLayerWidget v.1.2 is now available! This release provides a great GUI developed by Robert Scheitlin to more easily add Feature, Dynamic, and Basemap layers to your ArcGIS Web AppBuilder Applications. Take it for a spin, and please keep us informed of any bugs or desired enhancements through our Github Issue Tracker located at https://github.com/cmndrbensisko/LocalLayerWidget/issues.
Jan 12, 2015: Note that LocalLayerWidget v.1.1 is now available, which provides Click-To-Identify support and the option to add Feature and Basemap layers in addition to Dynamic layers.
The LocalLayer Widget is intended to allow the direct addition of MapServices to an ArcGIS Web AppBuilder application, without needing to wrap the desired services in an ArcGIS Online/Portal Web Map.
Basically, your basemap will still need to come from Portal/AGOL, but otherwise you just provide direct URLs to your own MapServices in the widget's configuration settings. The MapServices should load and display as usual in the map, and cooperate with the Legend, LayerList, and Attribute Table widgets. Click-To-Identify functionality won't work currently, though, because the current WAB implementation relies on Portal for all the popup info. As stated in the January 12th 2015 release, popups are fully customizable. Note that it's not an in-panel widget, so you'll need to follow a few extra steps in the project's Readme file.
Let's make Mapps accessible for everyone! With an eye on WCAG compliance, the Accessifizr Widget is designed to help make web applications keyboard navigable without having to modify core application code and UI.
https://github.com/cmndrbensisko/AccessifizrWidget
Information about how to configure this widget is available in the core Accessifizr.js library project available here, but the gist is that you create a JSON-based 'roadmap' detailing the keyboard navigation of your web application, and how it should change in response to users entering modal menus, hitting the escape button, etc. For applying descriptive alternate text to page elements, the widget leverages dojo's built-in internationalization support to specify multilingual alternate text strings. The end result is a web app that, hopefully, is a bit easier to use for people with mobility or visual challenges.
Hey Baba, I was able to get those environment.data.gov.uk WMS services to display fine via a proxy in my IIS-hosted application. Is your app available publicly? If so, I can try to remotely debug what might be happening on your end.
Hi Adam,
Thank you for your debugging, I have finally got it working after changing the URL to another WMS service. see below:
I guess my troubleshooting of the LL widget 2.2 beta is DONE.
Thanks for the amazing WORK
Baba
Hi Adam,
Did you reset the entire widget?, seems to have reverted back to the v2.0 on Github
Baba
Hey Baba; 2.2 isn't officially 'released' yet. Once you guys give it a general checkmark that it doesn't destroy your workflows, I'll prepare a final release. Until then, I'm keeping the candidates on a separate 'branch' of the repo.
Thanks Adam,
I was trying to test Barnaby's statement but lost track of the link or which I downloaded last
Baba
Hi drackleyad,
I don't know if this is a problem with LL but when you "Create Layer" from a selection using the "Select Widget" and do a print, the legend goes missing. I haven't tried this from layers coming from AGOL because all my web apps use the amazing LL.
Regards
Baba
I've officially released the 2.2 version of the LocalLayer widget. I'm still fighting a (hopefully) very intermittent bug related to layer toggling, but otherwise things seem to be cooperating. I will update the original post with a summary of the enhancements for this widget; Thanks again to everyone who helped test!
For the generous folks who offered to purchase me a beverage, I unfortunately don't make it around to conferences often, but I've added a tip jar to the repository.
Does LocalLayerWidget v2.2 work on Web Appbuilder Dev 2.2? I in stalled LocalLayerWidget v2.2 and followed the instructions( i think). i add LocalLayerWidget v2.2 it a new map i add layers/configure the widget i can not click on "Ok". Also when i try to select the map in web appbuilder the map never refreshes it just sitting there thinking, i have to reload the page.. Also if i have the locallayer widget active and i try to change the Theme from Fordable them to Jewelry box theme i get "Create Widget Error: Widge/coordinate/Widget" and i can't click "OK" to make the error window go away, So i am not sure if i am having these problems because i am on 2.2 or if didn't follow the instructions, any advice?
Yes, it does, and I just finished testing with WAB dev 2.3 version, works there as well.
Concerning the first part of your question - I had similar glitch when the LL widget was initially hidden from the panel while trying to configure map layers via LL.
Oh, as a remark, most of times I use the builder only to add the LL widget to the app as I configure map layers usually later directly in dev.server app confiration files, because this gives me a better understanding of the network traffic issues (if I should have any).
