Using WebApp builder 1.3, is it possible to modify one of the config files to change the Label on widgets once activated so i don't have to redownload it? If so, which config file and where does it sit? - New to this web app builder game.
Solved! Go to Solution.
Adam,
Sure in the apps main config.json you can find the widget and there is a label property for each widget listed there.
Adam,
Top stuff (as simple as that). Thanks Robert
Adam,
Don't forget to mark my reply as the correct answer.
Is there a way I can add an image and link to the widget label also?
Thanks!
Diane
Diane,
Your question has me confused. Widgets already have an icon/image.
Robert,
See image below. I have the layerlist widget open in the sidebar. I would like to add image and link along side the label.
Hope this clarifies things. Thanks,
Diane
Diane,
That would take a good deal of code to customize that theme to allow for that.
