Need assistance in deploying Web App Builder Data Grid Widget
4293
14
02-02-2016 07:39 AM
IanPeebles
I have a JavaScript application that contains a data grid, where the user can click on an icon to zoom to feature or click on another icon to open up a fact sheet.  Here is a preview:
I want to deploy this data grid functionality as a widget, but currently struggling to get it to work properly.  I know the steps to add in the custom widget to the Web Application Builder, but cannot get this tool to work properly.
I am attaching the code that contains the tool I want to deploy.  The zip file contains: 1. CSS folder with the layout.css file; 2. Graphics folder that contains the two icons; 3. the index.htm file which contains the code.
I have the feature layer I want to use hard coded, which is fine and what I want.  I want the data grid to appear in the panel within the widget.  So far, I have been unsuccessful in getting this deployed properly.
Does anyone have any ideas or approaches I can use?  Would greatly appreciate some assistance.
Ian
RobertScheitlin__GISP
Laurynas,
  There are many thing wrong with that widget download you sent me. You should be using the one I fixed on the thread that is marked as the solution to this question.
RickeyFight
MVP Regular Contributor
Does this work with the current version on WAB?
Not sure why it wouldn't.
IanPeebles
Ricky,
The data grid does work.  I just deployed an updated version of a public art app using the Web App Builder Developer Edition (version 2.8) last week and it contains a custom widget that contains a data grid.  Here is the example:
http://gis.edmondok.com/artinpublicplaces
RickeyFight
Am I able to add an image into the dgrid based on an attribute?
I need to be able to view a different image for each feature.
Ian Peebles‌ would you be able to share that widget?
