In the smart editor widget (web appbuilder - non dev edition), if you hold the control key down, it enables snapping when you create a new feature. However, when you simply want to edit an existing feature to move it to a new location, after hitting the "edit geometry" button, when you move your item, holding the control key does not seem to enable snapping, like it did for a new feature.
Does anyone know how to enable snapping on edit geometry? I don't see any mention of it in the help menu.
Thanks
Dan
