I am using the query widget in Web Appbuilder and have setup several query criteria. I also use the spatial filter "Only return features that intersect with the shape drawn on the map" in the widget, and set up as shown below. The problem I am having is the query will only execute if I use spatial filter. I need this to be an optionally used filter. When I set this widget up initially, the spatial filter use was optional. But some months ago the query wouldn't execute unless I used the spatial filter, which meant selecting a point on the map or drawing a polygon.
Is there a setting I am missing that will let this function optionally? Any insight into this issue is much appreciated.
