I am very new to dojo and I am stuck on this issue. When I try to add a new option, the error "addOption is not a function" arises. This is my code:
Widget.js:
function( declare, BaseWidget, Button, _TemplatedMixin, _WidgetsInTemplateMixin, FilteringSelect, on, keys, Parser, Memory, array, lang, map, FeatureSet, Query, QueryTask ) { return declare([BaseWidget, _TemplatedMixin, _WidgetsInTemplateMixin], { name: 'Cerca via', baseClass: 'jimu-widget-CercaVia', query: null, queryTask: null, postCreate: function() { console.log("postCreate!"); var mapFrame = this; this.inherited(arguments); this.ComuniSelect.addOption({disabled:false,label:'label',selected:true,value:1}); },
Widget.html:
Can someone point me in the right direction?
Bonus question: I would like to add to the FilteringSelect the option to search in the middle of the options. I read that this is possible setting queryExpr to "*$0*". How do I put it into my code?
Marco
Solved! Go to Solution.
Marco,
I don't normally add an item to my FilteringSelect, I normally clear it and add a new store. Here is what I believe will work:
var myStore = this.ComuniSelect.get('store');
myStore.put({disabled:false,label:'label',selected:true,value:1});
this.ComuniSelect.set('store', myStore);
Bonus question:
this.ComuniSelect.set('queryExpr', '*${0}*');
I Just discovered that there is not the addOption function for FilteringSelect. So I suppose that I have to work with stores... Can someone show me how to do this?
Marco
Marco,
Bonus question:
Thanks, Robert!
The solution you proposed for the bonus question works like a charm.
For the main question I think that I will follow your method: I will clear the FilteringSelect and add a new store. I think it is the best way to accomplish what I want to do.
