Widgets in Toolbar Display
4294
05-28-2015 11:26 AM
ChristopherHolewinski1
New Contributor III
I was wondering, is there a plan to make the widgets that are located in the toolbar re-sizable and movable?  I'm trying to make a viewer similar to the flexviewer we have, but I can't have the widgets taking up as much room as they do.  I read that it's due to the configuration of the theme.  For now I have moved them onto the map, which makes them re-sizable and movable, but it's not ideal.  Can anyone tell me if there is a plan to change the theme so that it is possible?  Or if not, is there a way for me to do it manually?
Chris
RickeyFight
MVP Regular Contributor
Yes it is possible.
What I did was:
Put this in widgets/About/style.css
#about_panel{
height: 250px !important;
This has to be done for each widget individually.
StanMcShinsky
Occasional Contributor III
Also don't forget to change the id of the widget in the main config.json file to something with out slashes
see here Widget in Panel Height
-Stan
New Contributor III
Thank you very much!  This is exactly what I was looking to do.
Chris
FlorianCADOZ
It doesn't say how to make in-toolbar widget being re-sizable and movable, but juste how to re-size them by modifying the CSS... Or I missed something ?
JunshanLiu
We'll add more themes in next release. I think maybe one of them is what you need.
