Parcel Fabric Registry Settings: pasting lines, merge courses before build
5780
7
04-04-2013 12:51 PM
AmirBar-Maor
See attached instructions to set the registry on your machine when:
  1. You wish to copy & paste more then 1,000 lines into construction
  2. You wish to prevent merge courses from running before Build
Amir
ChrisNelsen
Thanks for posting this. Came across this problem today finally.
AmirBar-Maor
ArcGIS 10.3 exposes the option to merge courses on build (off by default). The registry key is no longer needed.
NateArnold
Amir,
I can't find any additional information on this.  Would you please explain where to find this option?
[Edit: I'm using 10.3.1]
AmirBar-Maor
Hello Nate,
From the parcel editor toolbar drop down click 'Options'.
Under the advanced tab you can change the 'Build parcels behavior' to 'Merge connected lines at points where there is no bend'
Amir
NateArnold
Got it - thanks!
Is there a similar option when loading parcels using arcpy.LoadTopologyToParcelFabric_fabric?
AmirBar-Maor
There is no such option in the topology loading tool.
You can use other GP tools prior to loading the data (on simple feature classes) or use the interactive tool  'Merge Courses' that works on selected parcels
NateArnold
Amir,
Do you know of a GP tool that will operate on polygons and simplify only their straight (non-curve) courses?  We've looked at the curves & lines add in, but we have intentional overlapping polygons in our existing data and don't want to clean them up after generating polygons from lines and points.  Having the option to merge courses during data loading would be of great help in this situation.
