How can I find the WKID of coordinate system??
38413
8
08-04-2010 05:03 AM
JoshV
I'm hoping to find a list of WKID values that corespond to their coordnate system's.  Specifically USA Contiguous Lambert Conformal Conic.  I swear I saw this on EDN site but can't find this list anywhere.  Please advise.
Many thanks
JoshV
DaleHoneycutt
Occasional Contributor III
http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/Projected_coordinate_systems/02r3000...
(I googled "wkid projection list".  Unfortunately, we don't make it easy to find this info.)
JayJohnson2
If you have trouble, paste Dale's link into a browser.
DanielWalton
To piggy-back on this question, does anyone know where to find the list of wkid to latestWkid mappings?
MelitaKennedy
Esri Notable Contributor
I've asked a dev to create the list. It isn't in the doc (note to self: add enhancement request). I'll post the list here later today.
UPDATE: File is attached. This is valid through 10.4.0. Structure is:
object type: original WKID [authority] -> new/latest WKID [authority] Name
You'll see changes EPSG-EPSG, Esri-EPSG, EPSG-Esri
Example:
pcs: 102100 [Esri:] ->   3857 [EPSG:] WGS_1984_Web_Mercator_Auxiliary_Sphere
It also includes all objects types, including units, spheroids, etc.
pcs: projected coordinate system
vcs: vertical coordinate system
gcs: geographic coordinate system
gtf: geographic transformation
dat: datum
vdt: vertical datum
lin: linear unit
sph: spheroid
vtf: vertical transformation
Melita
DanielWalton
Thank you Melita!
DanielWalton
Thanks! Once it is published online, will you post a link to the page?
