Python script to calculate the area (!shape.area!),
4289
05-28-2014 12:40 PM
JamalNUMAN
Legendary Contributor
I wanted to calculate the are in a particular field. I used the script shown in the screenshot below (!shape.area!):
[ATTACH=CONFIG]34143[/ATTACH]
The ArcGIS quits.
What might be the issue here?
What could be the proper syntax?
Thank you
Best
Jamal
Jamal Numan
MattEiben
You're very close, the correct syntax is this:
!Shape!.area
If you're in a Projected Coordinate System, you can also use the "Calculate Geometry" option to get area as well.
MattEiben
!Shape!.area
JamalNUMAN
!Shape!.area
Thank you very much Matt. It works fine
[ATTACH=CONFIG]34184[/ATTACH]
Best
Jamal
Jamal Numan
RoryBennison
New Contributor III
Just to throw my ten cents worth in I use the following code: round(!shape.area@hectares!,1)
