Launching ArcGIS Pro doesn't recognize my user account
2460
5
07-16-2014 04:30 AM
DavidGilbert
I have an active ArcGIS Online account but when I launch ArcGIS Pro it says it was unable to successfully sign me in.   Anyone else having this issue?
Tags (1)
V_StuartFoote
MVP Frequent Contributor
David,
I am not yet up to speed on how the licensing will need to be handled, but I know that there will be "linkage" to the version of ArcGIS for Desktop that is authorized (either as Single Use or available from a Concurrent pool).
I've had no issues with using ArcGIS Pro beta, but then my ArcGIS.com account is linked to my Organizational account as well as my "My Esri" (Customer Care Portal replacement) account and I'm running on a system with ArcGIS for Desktop 10.2.2 Advanced installed, with an ARCGIS_LICENSE_FILE value set pointing to a concurrent pool.
Might suggest though that to structure this discussion you add a tag "licensing" and use the Move button from the Actions column to the right and move this to the GIS Space. And please let us know how this plays out for you.
Stuart
cc:
Larry Young
Robert LeClair
DavidGilbert
Thank you for your reply:   I am also running ArcGIS for Desktop 10.2.1 Advanced installed, with an ARCGIS_LICENSE_FILE value set pointing to a concurrent pool.  I am using Cisco AnyConnect with desktop, 3D and data reviewer borrowed
V_StuartFoote
David,
OK, so probably not related to the license for Desktop being available. Maybe it is an ArcGIS.com account SSO issue. Lets see if Larry or one of the other ArcGIS Pro devs will respond.
Stuart
DavidGilbert
Update:  while it did not work from my hotel I tried again at the Esri IUC and it launched.  Problem solved.
KurtBaron
I'm having the same problem since the UC2014, yet I still get emails thanking me for my participation in the beta program.  Am I in the program or out of the program?
