Problems with RuntimeManager and ProductCode Classes in ESRI.ArcGIS
9065
17
07-17-2014 08:17 AM
AngelicaMaria_Gomez
Hi
I'm trying to run a stand-alone application using ArcObjects, C# and SQLServer Express. I have an ArcGIS 10.2 Desktop license, then I did the following to bind the application:
I found the ArcGIS Version dll  (ArcGISVersion.dll) in C:\Program Files\Common Files\ArcGIS\bin\
I added the reference to this dll into my application
I included the namespace: using ESRI.ArcGIS in the class before to use any ArcObjects class.
I use the next instruction to bind the application:
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop)
The problem is I can't run the program, the compiler launched an error, RuntimeManager and ProductCode don't belong to ESRI.ArcGIS namespace and probably there is a missing assembly.
I also downloaded and install ArcGIS Runtime SDK for .NET I found in ArcGIS for Developers‌.
I hope somebody can help me with this.
nicogis
MVP Frequent Contributor
see this: Bind and License your standalone ArcGIS Engine or Desktop application | ArcGIS Blog
You don't need ArcGIS Runtime SDK for .NET because it don't reference arcobjects.
AngelicaMaria_Gomez
Hi Domenico
I know that, but the rest of my application use ArcObjects. The problem is with RuntimeManager and ProductCode classes. I'm not sure if there is a missing assembly because according to ArcObjects 10 .NET SDK Help‌, I don't need anything else but the code doesn't run
nicogis
In tab Build -> Platform target -> Have you set x86?
AngelicaMaria_Gomez
I have a 64 bit processor and installation, but I also try this and the error is still there, this happens in the compilation process.
nicogis
if you have 64bit you need set x86.
The assembly name is ESRI.ArcGIS.Version but the namespace is only ESRI.ArcGIS
using ESRI.ArcGIS;
AngelicaMaria_Gomez
Thanks for the information about setting the application
Did you mean that the correct instruction is
ESRI.ArcGIS.Version.RuntimeManager.Bind(ESRI.ArcGIS.Version.ProductCode.Desktop) ?
Because it doesn't work either
inside ESRI.ArcGIS I only have this
esriSystem
DataSourcesFile
DataSourcesGDB;
DataSourcesOleDB
DataSourcesRaster
Display
esriSystem
Geodatabase
GeoDatabaseExtensions
Geometry
Server
SystemUI
None of them have a Version namespace, even there is a document that say so: http://help.arcgis.com/en/sdk/10.0/Arcobjects_net/pdf/VersionObjectModel.pdf
I also checked the documentation of ESRI.ArcGIS namespace and on this link: ArcObjects 10 .NET SDK Help
the content is different to the content I have when I include the namespace into the program.
I also try with this instruction: "RuntimeManager.Bind(ProductCode.Desktop);" and add all the namespaces from ESRI.ArcGIS, but nothing change
nicogis
Can you do print screen of Solution Explorer of reference of your project and part of source code with using ?
AngelicaMaria_Gomez
Hi again
I attached the print screen. The code is quite simple because I separate this from the rest. Thanks a lotProblem_Geodatabase.png trying to find a solution
nicogis
The path of dll is C:\Program Files (x86)\ArcGIS\DeveloperKit10.2\DotNet\ESRI.ArcGIS.Version.dll. It's registered in gac so you should see:VersionDllAO.png
