Alternate Download Location for Arc Hydro Setup Files
6471
07-21-2014 04:51 PM
ChristineDartiguenave
In addition to the existing mft.esri.com download location, you can now also download the Arc Hydro Tools setups from the following location:
http://downloads.esri.com/archydro/archydro
Christine Dartiguenave
Esri Water Resources Team
V_StuartFoote
MVP Frequent Contributor
Christine,
Great! Might be of interest if  also posted to the Arc Hydro‌  and Hydro sub-spaces, in addition to here in the group.
Stuart
TonyHartrich
Christine,
From the alternate site, do I download the ArcHydroTools_x64 if I plan on loading it on a 64-bit, Windows 7 operating system.  ArcGIS 10.2 is still a 32-bit application, right?  Many thanks.
Tony
thartrich@quinault.org
V_StuartFoote
Tony Hartrich
ONLY if you install the optional 64-bit background geoprocessing extension:
10.2.2 -- ArcGIS_BackgroundGP_for_Desktop_1022_140426.exe
10.3 -- ArcGIS_BackgroundGP_for_Desktop_103_141996.exe
If the 64-bit background geoprocessing extension is installed, then you must install the  64-bit .msi of ArcHydroTools.  But again that extension is optional -- and most folks will have no issue with 32-bit geoprocessing.
