Set Default GPLinearUnit to Input Units
4364
07-28-2014 11:52 AM
AndrewFulton
How would I go about setting the default GPLinearUnit parameter's units to the same as an input, or even a default value of 'meters', within a Python toolbox? I assume it happens in update Parameters, but don't know how to approach this issue.
Your help will be greatly appreciated
### From what I've been able to figure out, there is no way to choose a default linear unit such as 'meters'; however, the linear unit in the tool dialog will correspond with the active Data Frame's Map Units. I think this only works in ArcMap. At least there is an ArcCatalog Window in ArcMap now
Message was edited by: Andrew Fulton
JustinBousquin
I've been trying to figure this out as well. I've somewhat been able to get it working using updateParameters, the trick is matching its required format and units.
#For a default meters (where param[1] is your parameter with datatype GPLinearUnit)
def updateParameters(self, params):
     if not params[1].altered:
          params[1].values = "0 Meters"
#Updating based on an input layer (params[0]) is trickier because spatialReference.linerarUnitName doesn't match up with the GPLinearUnit types
     if not params[1].altered and params[0].altered:
          spRef=arcpy.Describe(params[0].valueAsText).spatialReference
          params[2].values = spRef.linearUnitName
          if spRef.linearUnitName == "Foot_US":
               params[1].values = "0 Feet"
I'll let you know if I come across a better solution
JustinBousquin
To update a GPLinearUnit parameter (units) based on an input parameter (input) use parameterDependencies in getParameterInfo:
units.parameterDependencies = [input.name]
