Other reference layers - neither basemap, nor Editable layers
956
08-01-2014 08:03 AM
AdrianMarsden
Occasional Contributor III
Hi
I want to add some extra layers to my Collector app, which is to be used offline.  These layers are not part of the basemap, as the are dynamic, but are not layers I want edited in Collector.
I can set the webmap OK with these layers, but i cannot set it for offline mode as it doesn't like these reference layers, which are read in as an AGS map layer.
Is there any way I can do this?
Cheers
ACM
RussRoberts
Esri Notable Contributor
You cannot take dynamic map services offline. Right now you can only take tiled map services with export enabled or feature services with full editing and sync enabled. You can disable the editing on the feature service layer at the web map level and that will prevent the layer from being editable in the app.
Hope this helps
Russ
MichaelMiller2
Russ,
What is the status of using reference map service layers in web maps used in collector?
RussRoberts
Currently this is still restricted to either tiled map services or feature services that are sync enabled.
MichaelMiller2
Thought so.
Thanks Russ.
