Javascript Api Identify Raster pixel value
11991
22
08-20-2014 07:02 AM
BeakalGobena
I have this map loaded using the ArcGIS API
http://ags.servirlabs.net/ArcGIS/rest/services/ReferenceNode/TRMM_30DAY/MapServer
I want to let the user click on the raster layer and display the pixel value at that specific x,y location in a pop up window. While googling I found this example
https://developers.arcgis.com/javascript/jssamples/find_popup.html
explaining how to use IdentifyTask. Can I use this feature for a raster layer plus the data is already loaded do I need to make an extra request to get the values every time the user clicks on the layer?
by Anonymous User
Not applicable
Tim Witt Riyas Deen
Thanks! Teamwork!!
We needed this too. It just needed a small fix from Riyas' example. Here is an updated working sample, using our DEM:
http://jsfiddle.net/kevinmSAGIS/L834u2nt/4/
 Identify cell value with Popup in a mapServer raster
I had to add the following line because there's a space in Pixel Value:
                    "Pixel Value is : " + feature.attributes[ 'Pixel Value']);
TimWitt2
Here you go!
Edit fiddle - JSFiddle
RiyasDeen
Occasional Contributor III
Hi Beakal,
Noticed that Tim's sample is displaying the pixel's attributes like colour and layer name, i understand you are interested in the value of the pixel.
I have modified find_popup sample to display the pixel value.
AudyBarnett
Thanks Riyas. This is helpful. However, when I try to use your code I receive "undefined" as my pixel value in the pop up. My map service shows in the app and I can click to make the pop up show, but I do not receive a pixel value. Any ideas?
Thanks.
NMWater
New Contributor III
Hi Audy,
I have the same problem currently, I was wondering if you ever figured out how to tackle this issue? I still get undefined when trying to find the pixel value.
Many Thanks.
by Anonymous User
Not applicable
see my reply at the bottom for the fix NM Water
BeakalGobena
Thanks Tim and Riyas and  for the reply, IdentifyParameter and IdentifyTask is the write approach.
But I ran into another problem, on my page I'm loading four different layers at a time while the IdentifyParameter object accepts only one url as a parameter. Note that the layers are not in the same map service, they are in a different urls and different locations.
When the users click on any of the layer, I want to get the pixel values from the clicked layer.
Is this some thing possible?
by Anonymous User
Not applicable
Tim Witt Riyas Deen
Thanks! Teamwork!!
LloydBronn
This is great! I want to incorporate it into a script I'm working on. Will it work to reference the 3.17 API instead of 3.10?
Thanks!
RobertScheitlin__GISP
Absolutely
