TypeError: Error #1034: Type Coercion failed: cannot convert views::AGISHomeView@6396ae1 to spark.components.View.
5642
10
08-28-2014 12:11 AM
HaniDraidi
Occasional Contributor II
Hello all,
I am new to flex, and Flash builder, I followed the tutorial in this link: https://developers.arcgis.com/flex/guide/tutorial-query-your-data.htm to write a mobile mapping application that includes a query task, after writing the code, no errors appeared in the problems tab but there was 6 warnings, and when running the app the following error appears (Also shown in screenshots):
An ActionScript error has occurred:
            at spark.components::ViewNavigator/createViewInstance()
            at spark.components::ViewNavigator/commitNavigatorAction()
            at spark.components::ViewNavigator/commitProperties()
            at mx.core::UIComponent/validateProperties()
            at mx.managers::LayoutManager/validateProperties()
            at mx.managers::LayoutManager/doPhasedInstantiation()
            at mx.managers::LayoutManager/doPhasedInstantiationCallback()
Any kind of help is appreciated.
Hani,
___________________________________________________________________________________________________________
Screenshots:
1- Warnings:
2- Error:
Here is the code I used:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                     xmlns:s="library://ns.adobe.com/flex/spark"
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     xmlns="http://ns.adobe.com/air/application/4.6"
                     xmlns:esri="http://www.esri.com/2008/ags">
      <s:layout>
            <s:VerticalLayout gap="10"
                                      horizontalAlign="center"
                                      paddingBottom="20"
                                      paddingLeft="25"
                                      paddingRight="25"
                                      paddingTop="20"/>
      </s:layout>
      <fx:Script>
            <![CDATA[
                  import com.esri.ags.FeatureSet;
                  import mx.controls.Alert;
                  import mx.rpc.AsyncResponder;
                  private function doQuery():void
                        queryTask.execute(query, new AsyncResponder(onResult, onFault));
                        function onResult(featureSet:FeatureSet, token:Object = null😞void
                              // No code needed in this simple sample, since the
                              // graphics layer is bound to the query result using
                              // graphicProvider="{queryTask.executeLastResult.features}"
                        function onFault(info:Object, token:Object = null😞void
                              Alert.show(info.toString(), "Query Problem");
      </fx:Script>
      <fx:Declarations>
            <!-- Layer with US States -->
            <esri:QueryTask id="queryTask"
                                    showBusyCursor="true"
                                    url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"
                                    useAMF="false"/>
            <esri:Query id="query"
                              outSpatialReference="{myMap.spatialReference}"
                              returnGeometry="true"
                              text="{qText.text}">
                  <esri:outFields>
                        <fx:String>MED_AGE</fx:String>
                        <fx:String>POP2007</fx:String>
                  </esri:outFields>
            </esri:Query>
      </fx:Declarations>
      <s:Panel height="60"
                   backgroundColor="0xB2BFC6"
                   title="Query a layer (search for a state)">
            <s:layout>
                  <s:HorizontalLayout/>
            </s:layout>
            <s:TextInput id="qText"
                               width="100%"
                               enter="doQuery()"
                               text="California"/>
            <s:Button click="doQuery()" label="Do Query"/>
      </s:Panel>
      <esri:Map id="myMap">
            <esri:extent>
                  <esri:Extent xmin="-14298000" ymin="2748000" xmax="-6815000" ymax="7117000">
                        <esri:SpatialReference wkid="102100"/>
                  </esri:Extent>
            </esri:extent>
            <esri:ArcGISTiledMapServiceLayer
                  url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Physical_Map/MapServer"/>
      </esri:Map>
</s:Application>
RobertScheitlin__GISP
Hani,
  What Anthony is taking about is that you are taking the code from a Web Application sample and trying to paste it into a mobile app view, and you can not do that.
You view page code would need to look like this instead:
<s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
        title="HomeView">
    <s:layout>
        <s:VerticalLayout gap="0"
                          horizontalAlign="center"/>
    </s:layout>
    <fx:Declarations>
                        useAMF="false"/>
            <esri:outFields>
            </esri:outFields>
        </esri:Query>
    </fx:Declarations>
    <fx:Script>
        <![CDATA[
            import spark.components.Alert;
                function onResult(featureSet:FeatureSet, token:Object = null):void
                function onFault(info:Object, token:Object = null):void
    </fx:Script>
    <s:Panel height="80" width="100%"
        <s:layout>
            <s:HorizontalLayout horizontalAlign="center" verticalAlign="middle" paddingRight="2" paddingLeft="2"/>
        </s:layout>
                    width="100%"
                    enter="doQuery()"
                    text="California"/>
    </s:Panel>
        <esri:extent>
            </esri:Extent>
        </esri:extent>
        <esri:GraphicsLayer id="myGraphicsLayer" graphicProvider="{queryTask.executeLastResult.features}"/>
    </esri:Map>
</s:View>
AnthonyGiles
Hani,
Did you follow this part of the tutorial:
Getting started—ArcGIS API for Flex | ArcGIS for Developers
as it sets up the application to run in the web:
'Web (runs in Adobe Flash Player)' as the application type.
Not as a stand alone flash file in adobe air, which it looks like your file is trying to do
HaniDraidi
Hello Anthony,
Thank you very much for the help. First of all I am building a flex mobile project to make a mobile mapping app, NOT a web mapping app, and before I started coding, I followed "Getting Started" section in all steps and added the 3 swc libraries (agslib-3.6-2013-12-13, mx, and sparkskins) this is shown with the screenshots below:
1-
2-
3-
4-
5-
Hani,
        title="HomeView">
    <s:layout>
    </s:layout>
    <fx:Declarations>
                        useAMF="false"/>
            <esri:outFields>
            </esri:outFields>
        </esri:Query>
    </fx:Declarations>
    <fx:Script>
        <![CDATA[
    </fx:Script>
        <s:layout>
        </s:layout>
                    width="100%"
                    enter="doQuery()"
                    text="California"/>
    </s:Panel>
        <esri:extent>
            </esri:Extent>
        </esri:extent>
    </esri:Map>
</s:View>
Hani,
   Also the Warning you are getting can just be ignored. They are there because of importing the mx.swc (which is necessary).
HaniDraidi
Dear Robert,
Thank you very much for the help, I used your code; the error and the six warnings disappeared, but two new errors appeared:
1120: Access of undefined property Alert
1172: Definition Spark.components: Alert could not be found
an when I run the app and proceed the errors, it starts with a blank screen.
Thank you again!
1-
2-
3-
Hani,
   Sorry, That is because I am using Flex SDK 4.13.0 that has an spark version of the Alert. You just need to remove the spark.components.Alert and replace it with mx.controls.Alert;
HaniDraidi
Dear Robert,
You are Great!
It worked fine!
HaniDraidi
Robert,
Could you please recommend me a resource that help me to learn developing Mobile Mapping Apps?
BjornSvensson
Hani Draidi‌, I know you asked specifically for Robert's advice, but here is a link to the tutorial for
Mobile-specific application—ArcGIS API for Flex | ArcGIS for Developers .  You might also want to consider whether Flex is the right technology for you to use, especially if you are new to Flex and/or mobile apps.
Other options include the ArcGIS API for JavaScript and the iOS/Android/etc SDKs - see Documentation | ArcGIS for Developers or any of the "mobile" presentations from the latest Esri User Conference and Developer Summit.
