How to get informations from an WMTSLayer
5573
7
08-28-2014 12:46 AM
ArminMueller
New Contributor III
I have an WMTSLayer in ArcObjects. I want to get informations from this object. I found IWMTSLayerDescription and IWMTSServiceDescription as interfaces to get the informations i need. But i do not found any possibilty how to use these Interfaces.
Is there any out there who has a solution?
Greetings
Armin
Tags (1)
MatthiasSchenker
Hi Armin
The layer (ILayer) should also implement IWMTSLayer. Go to IWMTSLayer.Connection to get the WMTSConnection-Object. This object also implements IWMTSServiceDescription: You get to the indidual LayerDescriptions (of type IWMTSLayerDescription) via the LayerDescription Property of the IWMTSServiceDescription-Interface. LayerDescription is a list, you Need to specify a layer index to get Access to the individual layer.
Best regards,
Matthias
ArminMueller
New Contributor III
Hi Matthias,
i have tried this, but it seems that it doesnt work
wmtsLayer is a valid wmtsLayer. It shows me the TileMatrix and the name.
Dim wmtsCon As IWMTSConnection = New WMTSConnectionClass
wmtsLayer.WMTSConnection(wmtsCon)
wmtsService As IWMTSServiceDescription = CType(wmtsCon, IWMTSServiceDescription)
wmtsService gives me no information. All is empty
Armin
MatthiasSchenker
Hi Armin
I believe that you need to explicitly open the connection object first. Here is what you need in C#. If I do this, I do get an object for the serviceDescription.
IWMTSLayer wmtsLayer = layer as IWMTSLayer;
IName wmtsName = wmtsLayer.DataSourceName;
IWMTSConnectionName wmtsConnectionName = wmtsName as IWMTSConnectionName;
WMTSConnection wmtsConnection = wmtsConnectionName.OpenEx(null) as WMTSConnection;
IWMTSServiceDescription wmtsServiceDescription = (IWMTSServiceDescription)wmtsConnection;
Matthias
ArminMueller
New Contributor III
Hi Matthias,
now it works. Thank you
Armin
TomSchuller
Occasional Contributor III
Hy,
how can I choose in the WMTS-mapservice which sublayer should be displayed?
We have 1 WMTS-service with multiple layers in it.
I want to display only a specific layer from the WMTS-service
When I'm adding the simple "wmtsLayer", I'm always getting the first sublayer from it.
Tom
AhmedEl-Sisi
You can get a specific Layer by assigning layer identifier to LAYERNAME property.
Something like the following:
    private ILayer GetSpecificWMTSLayer(string url, string layerID)
            IWMTSLayer wmtsLayer = new WMTSLayer();
            WMTSConnectionName connectionName = new WMTSConnectionNameClass();
            IPropertySet propSet = new PropertySetClass();
            propSet.SetProperty("URL", url);
            propSet.SetProperty("LAYERNAME", layerID);
            connectionName.ConnectionProperties = propSet;
            wmtsLayer.Connect(connectionName as IName);
            return wmtsLayer as ILayer;
These are the seven properties you can handle with your property set:
URL, LAYERNAME, USER, HIDEUSERPROPERTY, VERSION, PASSWORD, CONNECTIONPATH
WWalker
New Contributor III
Is there any documentation for these properties?
