Is there any way to install HazUS on a computer running ArcMap 10.2.2?
5265
08-28-2014 11:01 AM
GwynnHarlowe
We need to start using HazUS but are running version 10.2.2.  Is there any way to install HazUS?
Gwynn
Tags (1)
DavidDenham
HAZUS 2.1 is not compatible with 10.2.2.  I was able to get ALOHA to work with 10.2.2, but when I tried to install HAZUS Arc Map kept crashing.  I am not certain if they will skip 10.2 and 10.2.2 compatibility and just make it compatible with 10.3.
DavidDenham
RickBurgess
HAZUS 2.2 has been released and is compatible with ArcGIS 10.2.2
HAZUS is a stand alone application, it is not intended as a networked solution and should be installed on a stand alone PC with ArcGIS 10.2.2. To clarify, don't save any files on a server for use in HAZUS models, configure & save them all to your local hard drive.
My understanding is that either the single seat or concurrent license of ArcGIS will work.
