Change style for Legend (Print task)
4016
02-23-2014 04:19 PM
by Anonymous User
Not applicable
Original User: mns
hi,
i'm using arcgis server 10.2 for publishing print task using custom template.
Everything works fine but i would like to change style for legend.. the default style just list all label..
are there any way i can change it?
this is the default style
[ATTACH=CONFIG]31692[/ATTACH]
this is what i want
[ATTACH=CONFIG]31693[/ATTACH]
any help would be appreciated... thx
by Anonymous User
Not applicable
Original User: GISDev01
You can just create your own MXD templates and use those. You can configure the Legend in your MXD however you'd like.
http://resources.arcgis.com/en/help/main/10.1/index.html#//0154000005n1000000
EvanLevy
I am having the same issue and I have created my own custom MXD templates to use for the print task.  I have built a blank legend and the legend gets built once it is exported to a pdf based on what layers are visible.  The link you included was what I used to make my custom MXD templates and create the geoprocessing service.  However, it never mentions anything about how to set up the legend to get it the way legend2.JPG is set up.  If anyone has figured out how to do this properly, please reply with a solution.  Thanks.
VictorCoelho1
Hello Evan,
You can test the Legend behavior directly on the custom MXDs , just need to add the services to ArcGIS Desktop.
If you right click on the legend element and go to properties, you should see all the legend properties.
