Getting an error when trying to do a query in esri-leaflet
6154
17
09-12-2014 10:42 AM
joepublic
New Contributor III
I am trying to created an app that when you click on a button at the top of the page will display only the countries that will satisfy the query attached to the button (see bottom of the file attached).
Here is the snippet of the code:
$('#NSM').click(function(){
     var buttonType = document.getElementById('NSM');
     countries.setWhere('type="'+ buttonType.value + '"');
I am using the "querying features #2" as my template.
The error I'm getting is
{"error":{"code":400,"message":"Unable to complete operation.","details":["Attribute column not found [Microsoft SQL Server Native Client 11.0: Invalid column name 'NSM'.] [MEP_global_data.DBO.test_bdry]"]}}
Any help would be appreciated
Tags (1)
PaulCrickard1
Occasional Contributor II
the error says you have no field named NSM. Is there a property named NSM in the data?
What does the HTML for the button look like?
PaulCrickard1
and the country value is in a field named type? What does the data table look like? what is the field holding the country?
joepublic
New Contributor III
Here is the url
"http://dev.consciousglobalchange.org/arcgis/rest/services/MEP/noRelate_tester/FeatureServer/0
The column name is "type" the value is NSM
Let me know if you need any more information
Chris
PaulCrickard1
try setWhere(" type like 'nsm' ").
ArcGIS REST Services DirectoryLogin | Get Token
Query: MEP_global_data.DBO.test_bdry (ID: 0)
Where:
Object IDs:
Time:
Input Geometry:
Geometry Type:
Input Spatial Reference:
Spatial Relationship:
Relation:
Out Fields:
Return Geometry: True   False
Max Allowable Offset:
Geometry Precision:
Output Spatial Reference:
Geodatabase Version Name:
Return IDs Only: True   False
Return Count Only: True   False
Order By Fields:
Group By Fields (ForStatistics):
Output Statistics:
ReturnZ: True   False
ReturnM: True   False
Format:
# records: 6
type: NSM
Polygon:
[-1.05925448094E7, 6331610.610799998] , [-1.05925143079E7, 6337259.6477999985] , [-1.05923596851E7, 6339015.385300003] more...
[-1.74327857678E7, 1.1523017382700004E7] , [-1.74324155192E7, 1.15212753389E7] , [-1.74266945879E7, 1.1507461465899996E7] more...
[-1.70654633969E7, 7965857.698700003] , [-1.70644136541E7, 7967666.887500003] , [-1.70635779787E7, 7968250.298199996] more...
[-1.91074667251E7, 9277683.944799997] , [-1.91073749979E7, 9276497.047700003] , [-1.91068790695E7, 9273703.769900002] more...
[-1.4875929794599999E7, 7612574.983099997] , [-1.4875929794599999E7, 7613688.5315999985] , [-1.4873456720800001E7, 7628072.728600003] more...
[-1.51547280122E7, 8013438.626999997] , [-1.5154136794300001E7, 8014083.521700002] , [-1.51351838718E7, 8009271.293399997] more...
[-1.8491374124E7, 8490460.355300002] , [-1.84912484443E7, 8489146.592200004] , [-1.84870155207E7, 8473950.735399999] more...
[-1.5023646974E7, 8052052.3552] , [-1.5023307227E7, 8053469.133299999] , [-1.5022131804499999E7, 8053527.569499999] more...
joepublic
New Contributor III
     countries.setWhere('type like"'+ buttonType.value + '"');
Didn't work... Got the same error: .... Invalid column name 'NSM'.
It thinks the column name is NSM instead of type
This is what I see in google's developers tool:
  1. geometryType:esriGeometryEnvelope
  2. geometry:{"xmin":-180.09,"ymin":11.50500000000001,"xmax":-0.08999999999999009,"ymax":85.95612673286779,"spatialReference":{"wkid":4326}}
  3. outFields:*
  4. outSR:4326
  5. inSR:4326
  6. where:type like"NSM"
  7. f:json
PaulCrickard1
the field is type and the value is NSM. I got that error when I had NSM wrapped in double quotes
when I type like 'NSM' I get the results as expected.
you can use = too but has to be single quotes around NSM.
PaulCrickard1
got it.
Here is my code. No Jquery.
<!DOCTYPE html>
<html>
  <head>
<title>NSM</title>
     <!-- Load Leaflet from CDN-->
    <link rel="stylesheet" href="http://cdn.leafletjs.com/leaflet-0.7.3/leaflet.css" />
    <script src="http://cdn.leafletjs.com/leaflet-0.7.3/leaflet.js"></script>
    <!-- Load Esri Leaflet from CDN -->
    <script src="http://cdn-geoweb.s3.amazonaws.com/esri-leaflet/0.0.1-beta.5/esri-leaflet.js"></script>
    <style>
      html, body,  #map {
        width : 100%;
        height : 100%;
    </style>
  </head>
  <body>
<button onclick="NSM()">NSM</button>
<div id="map"></div>
<script>
var you;
//var map = L.map('map');
var map = L.map('map').setView([35.10418,-106.62987], 13);
L.tileLayer('http://{s}.tile.osm.org/{z}/{x}/{y}.png',{opacity:.4}).addTo(map);
map.locate({watch:true, setView: false ,maxZoom: 16,enableHighAccuracy:true});
var nsm = new L.esri.FeatureLayer("http://dev.consciousglobalchange.org/arcgis/rest/services/MEP/noRelate_tester/FeatureServer/0");
      var popupTemplate = "<h3>{type}</h3>";
      nsm.bindPopup(function(feature){
        return L.Util.template(popupTemplate, feature.properties)
function NSM(){
nsm.setWhere("type like "+ "'NSM'");
nsm.addTo(map);
    </script>
  </body>
</html>
joepublic
New Contributor III
Paul,
Using the single quotes worked!!
I made some changes similar to the code you posted above so that the tilemap is displayed initially.
When you click on the button the countries that satisfy the query are over-layed on the map
Now I am getting the following error:  Uncaught TypeError: Cannot read property 'getBounds' of undefined
      countries.setWhere("type like "+"'"+buttonType.value+"'");
      countries.addTo(map);  <- placing this line here causes the error
Link to demo: Esri Leaflet Demo
Can you tell me what I'm doing wrong??
PaulCrickard1
I got the same error. It was because I was not running the sample on a server, but from my desktop. You have to run the code from a webserver or it will not work. Could that be what is happening when you run it?
I ran it from my server and it worked perfect. Had the countries and when I clicked them they turned red and data was on the right side of screen.
