Anyone sanitary/storm utiltiies currently using the LGIM?
6020
09-13-2014 01:50 PM
jasonstewart
We are in the process of vetting out the LGIM against our current GIS schema.  I understand the default, but I would like to see what other utitlies are using for their standards.
DallasPryor
The City of Tampa is using the LGIM. For our Wastewater Department it has been modified slightly.  We have completed an integration with a CCTV inspection application and have added fields to the LGIM in our gravity main feature class to accommodate pipe ratings.  We use the NASSCO standard for scoring pipe condition and while the LGIM is identified as being NASSCO compliant, it is not exactly so.  Slight modifications were made to material domains to match the current NASSCO standard.  We have also added fields for flow data and rehabilitation date and method in pipe and manhole feature classes.
JohnCenteno
Glynn County, Ga we use the LGIM for our Joint Water Sewer Commission. The JWSC was about to implement CityWorks and we took the opportunity to use the LGIM as we were going to have to make many schema changes to our existing database. Many of the fields we were going to have to create for CityWorks were already part of the LGIM. We did add our agency specific fields to the tables as well.
